Need Help!!!!!!!!!!!!!
Ok, first here is a little background about the car it is a 2000 TA that has a 383 we recently put a D-1SC on it and we are having a little trouble tuning it so here are a few questions I have. What types of values should I expect to see in the VE table? Also the car doesn't idle very well, does not want to stay running when cold. It surges pretty bad at low speeds, and it is puffing some major black smoke. Also I need some help tuning it for speed density. If anyone can help it would be greatly appreciated we are about to pull are hair out trying to tune this thing!!!!!!!!!
w/the VE values, in stock form they're only good for 1 bar ... once you enter boost you'll pass up the VE table.
If it's puffing black smoke then sounds like you're setup way too rich now... do you have any scans you can post up?
As for tuning speed density, you will need a custom 2 or 3 bar OS to do this (stock OS maxes out at 1 bar)
