F*ck DTC P0300.
F*ck DTC P0300.
guys this code is driving me crazy , I couldnt figure out whats the problem. I did an OBD scan 2 days ago and the codes were mostly for EGR and Air because I delete them along with my PCV system. The codes appeared after I did the following :-
stock heads swap , (Air ,EGR , PCV, AC ) removal , ls6 intake .
Car drives fine but i felt loss of power on low rpm`s.
any body been in same situation or expereinced this before?how to figure the problem if not?
I know that the main problem with this code that it has a variety of reasons why this code is there with no specific reason like other codes.
Thanks.
Thanks.
