Question on shift mph ?
My shift mph is set at 76 for the 2-3 shift, sometimes it hits the limiter, sometimes it doesnt, when it doesnt hit limiter it seems to hang, kinda like a flat spot, its killing my mph too, I have scanned it and my mph at the intended shift rpm is around 71-72, do you think dropping the mph down to 70 might help with the flat spot/limiter ? This is the settings from dyno tune, I have hp tuner now and IM trying to fine tune everything !
Thanks
Thanks
You have to meet two conditions for the car to shift, MPH and RPM. Set the MPH to a few mph lower then you want it to shift at and it won't hit the limiter. I would set it to like 68mph if you want it to shift at say 6200rpms. Account for any slipage you may encounter with the converter.
