o2 sensor codes still being thrown after o2 simms
well as the title says. also it says bank 1 is running lean? im just curious with the front o2 sensor running lean could that cause the rear ones to throw a code? the car has been dyno tuned. please help! thanks in advance
Your post is kinda confusing. If you have sims in, you should not be getting any rear o2 codes. Your bank 1 being lean is a whole new story, you might have a bad bank 1 front sensor, or your closed loop tune is off.
whats this closed loop tune? and no offense but i posted cuz im not sure why the rear o2's are throwing codes if i have the o2 simms like you said? i will get a new front o2 for sure tho.
anyone else know why might rear o2's are still throwing codes?
