WOT a/f ratio in SD mode. How to adjust?
Old 04-03-2006, 07:46 PM
DanaliHD's Avatar
Default WOT a/f ratio in SD mode. How to adjust?
I noticed that my a/f in SD mode is way off. like 16:1 or higher. I know I could adjust it using the PE table in HPtuners, but, i'd have to make HUGE adjustments. Should I assume there is another table I'm supposed to be changing instead? I want to get to 11.7:1
thanks
Old 04-03-2006, 08:01 PM
horist's Avatar
so long as you have a wideband, in SD mode force open loop, then use the open loop tables to force a safe WOT AFR like 13.0:1, then you can use the AFR % table just like normal to modify VE
Old 04-03-2006, 08:53 PM
DanaliHD's Avatar
i'm a simple man, lol. can you please elaborate? all i know is, i command 11.7:1 but see anywhere from 10-20:1 at wot. seems very random
