PCM removal question
i have a 99 ls1 camaro and am looking for a place to run a power wire to a speaker amp through the firewall i remember in a 98 there being a good spot behind the PCM... I tried to instead of taking the entire pcm out just remove the two banks off the top exposing the pins to take a peak behind it... however im a moron and im 99% sure i put them back the right way...is it possible to switch them and do it backwards put the top "plug" on the bottom bank and the bottom plug to the top bank or do they fit only in their respective locations? Please help thanks
Don't know if it's possible to reverse them or not, can't remember what they looked like. I wrote in pencil top and bottom when I removed mine. Anyway, on my car the "bottom" connector has another bundle of wires coming out of it going to the connectors on the fender well - yours is probably the same.
