need connector pinouts C220 and C230 for 1998 f-car
Old 04-11-2006, 10:35 PM
slow's Avatar
Default need connector pinouts C220 and C230 for 1998 f-car
I'm going to swap a 99+ engine harness into my 98 WS6, but need some pinout information for these 2 connectors on a 98, to see how hard this task will be.
Any help would be greatly appreciated, I will make detailed info about the swap for all of those who are looking into doing the same thing.
Thanks
Ryan
Old 04-12-2006, 04:11 PM
crewchef's Avatar
White C220
A, red, Generator feed to instrument cluster
B, tan, Oil pressure to instrument cluster
C, brn/wht, low oil level indicator
D, not used
E, not used
F, blk/wht, ground? not noted in service manual, I grounded it.
G, grn/wht, VSS
H, wht, skip shift indicator manual trans
J, yel/blk, vehicle anti-theft system starter enable relay output-coil
K, dk grn, coolant temperature feed to instrument cluster
Blue C230
A, gry, clutch anticipate signal V6 only
B, brn/wht, service engine soon indicator feed
C, not used
D, wht, tachometer signal to instrument cluster
E, dk blu, Theft deterrent fuel enable feed
F, dk grn/wht, A/C request signal
G, ppl, brake pedal switch output-torque converter clutch V6 VIN K auto trans
G, brn, fuse output ignition 3 type III fuse V6 vin K auto trans
H, lt blu/blk, (automatic) TCC switch power feed
J, orn/blk, (automatic) park-neutral feed from transmission range switch.
J, lt grn, back up lamp feed V6 VIN K man trans
K, ppl, output field servce enable
Not sure why there's two G's and J's but that's what my notes show. I'll check the actual service manual later and let you know if I see anything different.
Quick Reply: need connector pinouts C220 and C230 for 1998 f-car
