Dtc Heeeeeeelp!!!!
Dtc Heeeeeeelp!!!!
I hope someone can help me here!! I'm tunning my boys 04 Z06 and I wanted to check the DTC's to see if any had been thrown after our run. I always do just in case there is something that doesn't set off a MIL. This is by far the craziest thing I've seen because it doesnt even exist in the EFi Live tunning software!!!
DTC's are:
B0333 HVAC Control Module
B0361 Same thing
B0441 Same thing
Please if anyine has any ideas throw em at me. Much appreciated guys
DTC's are:
B0361 Same thing
B0441 Same thing
Those are Body Control Module codes, hence can't be removed since efi works w/the PCM (or in case of newer vehicles, TCM and ECM)
unfortuanetly I'm not sure what the fix is for this... does your HVAC work properly?
From what I know it does!?? But I don't even know how to tell if it is or not so I guess I didn't really help you any!? How can I tell what the deal is?? I looked it up on the OBDII diagnostics page and it's saying a few different things!!
B0333 was outside temp sensor open.
B0361 motor 1 feedback short.
B0441 LH mix motor out of range.
I have no idea......
Is there another handheld or program we can get to clear these or are these mechanical parts that need to be replaced first then try clearing the codes with EFiLive
You can clear codes manually, Autotap won't even work on my Z06 unless I clear the codes.
You can search this forum....or just hold the "options" button while pressing "fuel" 4 times within ten seconds.
It will scroll through all the codes and then go into "manual diagnostics" once in manual you can press the "options" button again and go through each control module. Pressing and holding "reset" until it beeps will clear the codes in that control module.
I don't need help clearing the codes!!! I have EFi Live so that's not the issue. We're trying to figure out what needs to be replaced so that this won't continue to happen!! Thanks for the info though
