ECU relearning?
Old 04-21-2006, 10:07 PM
CashMoney's Avatar
Default ECU relearning?
So I went and installed my laser shifter while doing that the pcm and the battery were both disconnected. After all was said and done (3 hour later) I hooked everything back up... I then started the car up and the idle was really low about to kill the engine. It did this throughout a 30 min drive in the city everytime I stopped the idle would go low.. Throughout the drive it got a little better and better to the point the idle was normal while stopping.
This was the PCM relearning the fuel trims correct?
Also Will I need to retune the car. I used HP Tuners to drop the fan temps and disable cags..
Thanks
Nate
Old 04-21-2006, 10:48 PM
DrkPhx's Avatar
You will not need to retune the car. If you disconnect the battery and do not perform the idle relearn procedure, it will take a couple of drive cycles to complete the relearn. Sounds like it's already fine, so you should be okay.
