car threw a ses code for the TPS need help?
I just added the fast intake 90mm w/nick williams th-body. my car was tuned and now from time to time it will stumble a little on take off then run good. tonight it threw a SES code for the TPS sensor on my th-body. can the sensor be adjusted to the proper reading(4.6 volts??) or is it a fixed reading on how much it puts out? my th-body hole has been drilled a little bit bigger,but so was my stock th-body and never had a problem. if it cannot be adjusted,what do i do to find the problem. i have no auto tap or things like that.
thanks, mike c.
thanks, mike c.
