trans am missing
trans am missing
got 01 t/a with pat. stg 2 heads tsp 231/237 cam.. i have changed the maf, run speed densty tune, changed the 02s, plugs, fuel filter and the fuel injectors with zero change. after about 5 min the cars fouls out the plugs and just misses and has no power.. i just got rid of the p0101 code.. i also have drilled out the hood baffles.. now for diagnostic info the map at idle runs about 73 and with the key on it is at 93. the maf runs about 8-9 grames a sec. the trims are off but that has only been doing it since the problems. at idle the fuel pres is about 65 and with key on it is 55 psi. i have 4 log files and my tune hp tunners
