What is the stock tune timing set at?
Old 05-08-2006, 06:30 PM
DJB
12 Second club
DJB's Avatar
Default What is the stock tune timing set at?
What is the stock timing and how is it set up? Does it go from lower degrees to higher or does it start higher then get lower as the motor revs. What is the highest degree 24 26 ect..
Old 05-08-2006, 08:38 PM
white2001s10's Avatar
It looks a lot like this table for a GTO.
http://www.mpedrick.net/gallery/albu...able_small.jpg
Old 05-09-2006, 08:18 AM
SSpdDmon's Avatar
Actually, if he has an '00, it looks a bit different.
12.700195 - 1000RPM
13.007813 - 1200RPM
15.996094 - 1400RPM
17.995606 - 1600RPM
19.995117 - 1800RPM
23.994141 - 2000RPM
27.004395 - 2200RPM
27.993164 - 2400RPM
27.993164 - 2800RPM
29.003906 - 3200RPM
27.993164 - 3600RPM
25.004883 - 4000RPM
23.994141 - 4400RPM
23.005371 - 4800RPM
25.993652 - 5200RPM
27.993164 - 5600RPM
27.993164 - 6000RPM
File Type: zip
