OBD II to OBD I conversion.
What do you have to change on your car to switch to obd I. Replace the obd II pcm with the Obd I pcm and knock sensor? Anything else? If there is a thread to this already, feel free to post it.
That's it.
Or you can take the OBDI PCM, solder a 3.9k resistor between blue 22 and blue 1 on the back side of the printed circuit board (between the row of pins - be sure to insulate with electrical tape or heat shrink), and leave the stock '96 knock sensor in place.
