Any ideas of duty cycle with stock injectors?
Old 05-17-2006, 07:33 PM
SPRAYED 01's Avatar
Default Any ideas of duty cycle with stock injectors?
Mods in sig with the addition of tsp ported ls6 heads and a fast90/90 setup. Plan on puting down 420-440hp. Think ill be maxed out?
Old 05-17-2006, 08:40 PM
SSpdDmon's Avatar
Maxed out how? On stock injectors, you're probably maxed out already. HP wise though, you've got a long way to go before you're maxed out.
Old 05-17-2006, 10:13 PM
WS6 GreeN's Avatar
I put down 488 rwhp and somehow haven't maxed out my injectors yet Actually running too RICH!
Old 05-17-2006, 10:32 PM
SSpdDmon's Avatar
Let me clarify....injectors will run past 100% duty cycle. Is this ok? For the long term, probably not. Most people target 80%. Chances are, you're either at or above 100% already. Can you get more fuel from the stock injectors? Most likely. Can you get more fuel from the stock injectors reliably in the long term? I woulnd't want to find out the answer to that question the hard way...
Old 05-18-2006, 07:24 AM
SPRAYED 01's Avatar
Thanks for the info. i found some 30lbs svo injectors for $150. cheap insurance.
Old 05-18-2006, 09:37 AM
Runn's Avatar
Look at my injectors... I know, but i am looking for bigger, Had racetronix #50 but i couldn´t tune them in...
white2001s10's Avatar
I'd say your at least in the high 90's %-wise.
