cylinder balance test, what does mean,,
Originally Posted by zrater
anyone , just wondering what the # means thanks
Cylinder Balance: The cylinder balance test calculates % of efficiency using current RPM. RPM is gauged with all injectors running normally. Injectors are then cut 1 cylinder at a time and the new RPM is compared to the pre-test RPM to determine % of efficiency.
can you tell how good the rings and piston seal or what cyl is better than the other...
more info: http://www.hptuners.com/forum/showth...linder+balance
Test on my vehicle:
