deleting rear o2 sensors
Old 05-24-2006, 03:54 PM
snksknr's Avatar
Default deleting rear o2 sensors
How can I delete the rear o2 sensors using HP Tuner?
I tried using the search but only found other info about o2's, nothing about deleting, any help would be great, thanks.
Old 05-24-2006, 04:59 PM
bshell's Avatar
Go through the DTC list under the Engine Diagnostics tab in the Editor and set all of the O2 Sensor 2 codes to 3-No Error Reported.
Old 05-24-2006, 05:03 PM
daryl2cb@yahoo.com's Avatar
bshell got it.
Old 05-24-2006, 05:06 PM
bshell's Avatar
Also, forgot to add that you will also need to delete the CAT efficiency codes as well. Set P0420 and P0430 to 3-No Error Reported. Make sure that COT is disabled under the Fuel Control tab.
Old 05-25-2006, 10:51 AM
snksknr's Avatar
Done, thanks bshell.
