Rev limiter and Nitrous
Old 05-27-2006, 09:53 PM
Technoman64's Avatar
Default Rev limiter and Nitrous
I have set my rev limiter to 7,000 Rpm for all gears. I have a M6 with 3.73 gears. When I do a run with no nitrous the rev limiter works as expected. Does not come on until 7,000 rpm. When I use the nitrous in 2nd gear it limits at 6,000 rpm. I am NOT running out of fuel. It seems to go higher in the other gears. Sorry I do not have a log file.
I set the max torque to 640 which was the max allowed. Does this setting in EfiLive have anything to with this problem?
Not sure what I am missing here.
Old 05-30-2006, 03:08 PM
OldSkool69's Avatar
In HP Tuners forum I read thet in some vehicles (ozzies) raising the original value of the max torque leans the mixture, you should check that out. Return to ur original value and make a pass.
