My car = BDNWW
Old 06-21-2006, 09:39 PM
68ss_00ss_87_95's Avatar
Default My car = BDNWW
took my car to the track today hoping to find someone knowledgable about maf code p102 i believe it was....so before i ask for help i decide to do some idiot checks (fuses, connectors...etc) 1 fuse for "ENG SEN" was blown, so i replaced it...still has 5 codes(no change), tried replacing maf with aftermarket 1 i had lying around to see if it was the maf...nope, didnt help....put stock maf in and then the car makes a air sound whenever i touch the gas....kinda like the sc is blowin air out of somewhere...couldnt find out from where....prior to changing all this stuff the car would idle and indicate 0% load....now its indicating ~4% at idle....got upset and started driving home to test it to see what the hell i did and now its hesitating, and the higher the rpm, the louder the air noise is...air to fuel ratio is somewhat to how it was before....can anyone help me figure out why my car hates me? it also pulled the 801 code 2 times...at the same time which also is wierd....
Old 06-21-2006, 10:37 PM
ZL1Killa's Avatar
air noise? maybe the vacuum line? somewhere?
Old 06-22-2006, 06:08 PM
im gonna keep lookin.....it definately isnt helping having to work 80+ hour weeks
Old 06-22-2006, 08:58 PM
YsoFast's Avatar
pluged cat? My brothers s-10 just did that a few weeks ago. It sounded like a vacume cleaner when you got on it and it fell on its face at anything over bliping the throttle.
Old 06-22-2006, 09:47 PM
i found the air leak....intake connection on sc box folded in a little bit...musta tightened it down a little too much....hopefully it works fine after that...
