MAF Translator
MAF Translator
does this really work? i have a granatelli maf, and i was told that it does nothing for me because that i need recalibrate my computer for that mass air.
I used to have one years ago, but I used the stock MAF. The later version Translators had a switch for 85mm MAF's so you could switch between stock and aftermarket. Honestly I would ditch the GMS MAF and use the Translator. You will get better results, but you do need a datalogger to view the fuel trims so you can adjust the Translator correctly. Curious, are you using this for a 402 setup?
