High o2 millivolts and knock retard
Old 07-23-2006, 02:41 PM
Ls1Bait's Avatar
Default High o2 millivolts and knock retard
I Just took the car out and did some logging and I am getting knock retard and high 900 millivolt numbers when I floor the gas (closed loop they call this right). So I would assume that the car is running lean? What should I do to Fix this? I tune with LT1-Edit.
__________________
Old 07-23-2006, 02:59 PM
GOaT Cheese's Avatar
900 mv is rich. As would be expected at WOT. As far as knock/detonation...dunno
Old 07-23-2006, 03:13 PM
Ls1Bait's Avatar
should I try some higher octane to see if it is false knock?
Old 07-23-2006, 03:45 PM
It may not be "false" knock. You could try better gas. Alot of detonation is caused by camshaft design. The factory gets away with 11.0:1 ratios because their cams are on very wide (116 deg.) LSA's. What is the lobe seperation and Intake center line of your cam? You may be creating a midrange scavenging pressure range that the computer cannot compensate for.
Old 07-23-2006, 04:44 PM
Ls1Bait's Avatar
its a 230/236 565/565 112LSA. Yea it seems wierd that i would get knock if im running rich but im new to this?
