sticking idle
sticking idle
Some suggested posting this here........
Please help
I've done a search, read a ton. Now asking for advise
Installed a 58mm holley throttle body
When the cars off it closes fine
When its running to idles at 1500 rpms
The blade doesnt close all the way
I've slotted the throttle postion sensor....... no luck
HELP!
Thanks in advance
Please help
HELP!
Thanks in advance
How have you verified the throttle body is sticking? I'm assuming you don't pump the gas pedal when you're trying to start it?
If it really is sticking, clean the moving parts in there so it can close. I'm suspecting your problem is related to the IAC.
