tunning time
Old 07-24-2006, 01:12 PM
Christian8A's Avatar
Default tunning time
Ok, Im heading to the place where they are going to do a tunning for the first time to this car, is a Z28 2001 with 29k miles, stock internals, ok Im going to be spraying 150shot .. What do I have to ask for them to do basically cuz itll cost some money It better be worth it, and Im sure they know but just to make sure what is the most important things to do for that shot
thanx
Old 07-24-2006, 01:38 PM
SSpdDmon's Avatar
If you're going to tune your car for nitrous, you won't be as fast as you could be off the bottle. Typically, I believe it's best for them to pull ~3 degrees of timing for a 150hp shot (wet I hope) and get your AFR (on the bottle) close to 12.0 or so. It'd also be a good idea to go with a colder spark plug (TR6 or similar). I think that's about right for nitrous. Check in the NO2 forum... https://ls1tech.com/forums/nitrous-oxide-10/
