lc-1 wideband problems
Ok so I installed the wide band according to the efilive tutorial but my display is showing me what I belive to be the correct afr and my efilive is showing a different number. any ideas what could be wrong?
I had the command afr guage on the "dash" and i kept looking at it and i finally realized that command afr was also a table for the pcm....then i did a little more searching and i found the pid for the afr. i still dont know how to get that as a graph on the dash but i set it up to record on the charts.
To get it as a gauge on the dash, right click and add gauge (choose the AFR gauge); then right click on that gauge and change its pid to the WB AFR pid, and save as with a different filename.
To get it on the chart, right click on a chart pid that you don't want (or an empty one), select other pids and select the WB AFR pid; then right click again and select chart properties, and set the upper/lower display bounds (say 20 and 10), save it and close it.
Press F1 for help, scroll down to the dash section.
