I think I fried my wideband...
I have an LC-1 with a dynotune gauge wired into my car. Last week I was doing a plug change on my car. After finishing, I went to start the car and it ran like total crap. I revved it up a bit, then turned it off. Thinking that I probably forgot to hook something back up, I checked under the hood and noticed that I had forgotten to plug one of the coil pack harnesses back up. Plugged everything in, started the car, and it ran like a champ. Since that, however, my wideband has not worked properly. I'm guessing running the car on 4 cylinders really screwed the sensor up (it was SUPER rich since 4 cylinders were not burning the fuel).
Anyways, I have tried recalibrating and nothing. Did I fry the sensor? If so, where can I get a decently-priced replacement?
Take the sensor out and clean it up. Its probably just all dirty fom all the gas/carbon coming out of the exhaust. Rarely do exhaust sensors go bad from something like that, it most likely just needs to be cleaned up
The sensor is readily available from the Volkswagon Dealer I picked up a spare while troubleshooting my LC-1 for I think $65. The part number is listed in the instruction set, that is downloadable from Innovate.
