2 OBDII Ports???
2 OBDII Ports???
Ok, I have an Interceptor ScanGuage and EFILive I would like to be able to use them both at the same time. Would it work to get a OBDII port out of a junk car and put it next to my current port and splice in the necessary wires for the ScanGauge to work? Anyone see any problems with this? Would the two devices conflict with each other while trying to exchange data with the PCM? Any one have any thoughts on this?
Aeroforce makes/sells a kit where you can use 2 of the interceptor gauges at the same time with a special adapter. If you bought that adapter I dont see any reason why you wouldnt be able to do what your trying to do.
Originally Posted by slow
You can make a Y cable, but you may run into problems when you have 2 devices receiving the same information back, If they are both going to be address to the same tester address.
Ryan
Ryan
