LC-1 cable used with LM prog - need help
I am missing the cable and plug used for the LC-1 to PC connection, for example when using the LM programmer.
The cable is a DB9 serial connection on one end, and a stereo pin on the other. The plug is just another stereo pin with some type of shorted ends I assume.
If anyone knows the connections or can use a DVM to tell me which serial pin goes to which part of the stereo pin plug, that would be awesome. Likewise with the plug. if you could verify how that is terminated.
Thanks
Chris
Thanks
Chris
Originally Posted by Innovate
Serial Program Cable (LC-1, XD-1, LMA-3) - P/N: 3746 - #3746
The Serial Program Cable will allow you to connect any of the following devices to your PC. (LC-1, XD-1, LMA-3)
