Cab't re-enable closed loop after tuning
I use EFI Live and after having recalibrated my VE tables in open loop, speed density mode I re-enabled the LTFT parameter to see how my LTFT's were doing. I noticed that there was no data in the cells of the LTFT map as I logged the data even though there were data counts. The MAF sensor by the way is disabled so I'm in closed loop, speed density mode. I've checked the tables in the tune file to make sure that I had enabled LTFT learning and also reset engine coolant temperature table for enabling closed loop operation. Commanded and WB02 AFR's are very close. I've gone back through the tune tables to make sure I didn't miss something but can't find anything wrong. Anyone have any idea why I can't get an LTFT readings?
What are the values for B3801 and B3802
