Advance @ WOT
Advance @ WOT
Can someone tell me what the timing advance is on a stock tune @ WOT?
I ran the car over the weekend but was disappointed to find I was down 4/10ths to 5/10ths over my previous bests so I logged a few passes and found I was only running 23-25' of advance @ WOT. Is this the norm?
I know weather plays a big factory but I was comparing previous runs in the same DA.
Thanks for the input. To clarify I had no knock on any of my logs.
I did wonder if maybe I was running on the low octane table but I didn't know how to determine this with HP Tuners.
One more important factor I should add is that I normally ran 94 octane fuel but I recently switched to 91 for a couple reasons. 1 was that the 91 I use has no ethanol added and 2 the car was tuned for 91 according to the owners manual.
Maybe I should run the 91 out then go with 94 again for a couple tanks and see if it helps.
