Megasquirt
I dont think there is any way to use the factory crank trigger and wheel yet. So the next best way would be to mount a 36-1 trigger wheel on the the crank pulley with a VR sensor. Then use the Toothed wheel decoder ignition code. You will need a v3 board with 4 vb921 coil drivers. Run your coils in wasted spark mode.
