Wideband sensor is giving ER1 error...
Hey guys.
My wideband FJO sensor has been giving me an ER1 error.
I noticed it also just recently changed to 00.0 or something like that.
Any idea how to fix it, or what could be wrong?
TIA.
TIA.
Try unplugging the sensor and plugging it back in, err 1 is when it is reading no sensor hooked up. I don't know what code it gives when the sensor is bad but when I unhook mine it does err 1. I think when the sensor goes bad, it just gives crazy readings, and fluctuates alot.
The line on the module that goes to the sensor, there is a connection there that could be not connecting, and then "because its an extension" there is another one where the sensor plugs to the extension. The extension should be like 3' long. So two plugs on the same line. Just follow the sensor, till you find them, it should be where the old 02s were, if your in sd. If not it has its own bung. If this don't work id check the ground, although I don't think that's it. If this all fails call fjo. At 204 254 5623 option 3
