What would cause 4 lights to be on at once? Brake, Service vehicle, TCS OFF, and ABS?
Basically i started my car and ABS INOB, Service vehicle, Emergency BRAKE and ASR OFF lights were all on and stayed on? Im gonna have my car scanned, but any ideas of what would cause it? I started it up again later and no lights, but im guessing it set a code, seems like something obvious if it lit up 4 warning lights.
2000 z28
2000 z28
Do you have a 3 channel setup or a 4ch? TCS or no TCS? You can have all these lights and a common scanner will not show any codes. They are all brake controller/abs module related. A Tech2 can and will reveal the fault. Wiring, as stated before would be the first place I would check. If you were to unplug the ABS module on a otherwise working system you would get the same indications. Ultimately, the module could concieveably go bad but I wouldn't shotgun that unless a Tech2 told me to. Good luck. If the problem does turn out to be your abs module and you don't have TCS and want to keep abs pm me, I recently deleted my abs for a line lock, and proportioning valve which by the way I think should have come with the car stock
yeah i have ASR/TCS, same thing. Haven't dynoed or anything. Basically i have been hearing a bearing type noise out the back for the last month or so, not sure if related or not. I hope its not electrical and its a cut and dry thing if you know what i mean. Someone else had the same problem and turned out to be a speed sensor. When i did drive back home, no lights are on. Ill let you know what if anything my mechanic finds.
