flashscan not reading what the lm1 does
7 Second Club
i finally got the wideband lm1 hooked up and actually responding with efilive... when i just get in the car and turn the car on... not start it... the lm1 reads around 11.0 and flash scan says like 21.0... why are they differing... when i start it should they look the same?
i just fouled some plugs so i cant start the car if your wondering.... aahhh the wonderful world of tunning
The LM-1 should read in the 20-21 range with key on and not running. It maybe the pid loop you setup. But I'd check the sensor accuracy and LM-1 calibration first then work on the Interface.
But your problem should almost be reversed Are you using the pid in the efilive list for the lm-1?
7 Second Club
right... when i just turn the key on NOT START it reads about 21AFR... its doing that right now... i was just trying to get the wideband setup while my car was down for the night....
i fouled my plugs so i couldnt start the car to see if the readings came back down.
i was just seeing if this was normal or not...
but what gets me is the lm1 says around 13AFR i think when the key is just on...
thats what was confusing me... is that the lm1 and efilive were reading different.
7 Second Club
: Are you using the pid in the efilive list for the lm-1?
