Diablosport predator questions
-What increments can you adjust on the shift points? Does it adjust for all gears, or can you tune all shifts separately? Can you edit downshifts as well as upshifts? Does it go by MPH, RPM, or both?
-What adjustability do you have with the rev limiter <100 rpm increments?>
-What fan settings can you program?
Thanks!
Thanks!
Thanks!
Thanks!
OK, here goes.
Shift points-100rpm increments.All gears individually.Up/downshifts can be programmed based on mph AND rpm. That was easier than I thought it would be!
Rev limiter-10rpm increments(stock is 6190, you can put it at 6200, pretty sweet!)
Fan settings-set on/off temps for high and low speed fans
Thanks
Mike
