Turned SES light off, now funky idle.
I don't know if this is the right forum, but i installed a TSP lid and then took it for a quick spin and everything went great. My SES light has been on for a while due to a "clutch circuit switch malfunction" whatever that is. So I reset the light by pulling the PCM BAT and PCM IGN fuses according to install university and now it idles low for a few seconds then kicks up. The funky idle happens at start up and everytime i come to a stop sign or have to stop for any reason. Is this b/c I reset the ECU and it just takes time to get back to normal? I let it run and took it for a quick drive, a total of about five minutes. If it just takes time to get it's readings back to normal how long will that take? Oh yeah, performance also seems to be suffering from this issue.
Thanks,
Matt
Thanks,
Matt
Thanks,
I dont know how to fix a "clutch circuit switch malfunction." I did some research and it says that when you depress the clutch it is supposed to change the voltage but that is not happening. I don't notice anything different since the light came on. Any ideas on how to fix it?
I have a similar problem but the SES light is tuned out on a lot of things so I'm not sure if thats what the problem is or not. Anyone know how to check/change the clutch circuit switch?
