Need help with WOT timing please.
I just got HPT,did my first WOT log and discovered I have 3.3 KR. It starts from 3800RPM and goes all the way up, Ive also seen up to 37.5* of timing right before the VCM retards it to 24*. The tune on my car was not stock, I have never had a factory tune so I have no Idea where my timing table is supposed to be. I'd like to get the kinks worked out of my current timing table though, anyone know what I can do to back the timing down? I dont even know if the values on the high and low octane spark table cell blocks represent actual timing degrees or not? Also can I smoothe these tables like you do with the VE tables? BTW , I do have a LM1 and my AFR at 100% TPS is 11.9
Can I copy the KR Histogram and "special paste subtract"?
LS1TECH Sponsor
Originally Posted by foff667
There should be plenty of stock files for your viewing pleasure at www.hptuners.com just login & go to the repository then download as many files as you'd like.
yes
sounds a little rich for an NA application
yes
yes
yes
Thanks again for giving me help, I really appreciate it!
Please excuse the duplicate of this post on the forum you moderate.
