Popping and loading up?!?!
Old 12-03-2006, 10:59 PM
chrismcdaniel's Avatar
Default Popping and loading up?!?!
Of, i finally got the car to idle and i figured out how to keep it from dumping fuel in after it warms up. I have some issues that might be easy for some of you more experienced guys to figure out.
i have a 12:1 CR LME 408 Stroker in an A4
Im running a Vic Jr. Style intake
TFS 225 heads
SD Tune
I ended up haveing to raise the VE tables 10% from 400 - 2000 RPM to keep the STFT's close to Zero, which allowed the LTFT's to stay at about -8.6...most of the time anyways..
I know im still reading a little lean..
But, I took the car on a little test drive, and the car would sputter and backfire in the lower RPM's Loading up and blowing black smoke..
I obviously am running too rich in the lower RPM's based off of my raising the VE Table 10% to get it idle without leaning out..
I just cant seem to find the happy medium..
What am i doing wrong?
Thanks,
chris
Old 12-03-2006, 11:02 PM
S99TA's Avatar
do you have a wideband o2 sensor?
Old 12-03-2006, 11:07 PM
not yet... i know, i have to get one.. but i just got HP tunners and was just going to get it running good enough to take it to the dyno and tune the A/F.. i just assumed i would be able to get it close without it by watching the what the Fuel trims where doing..
Old 12-03-2006, 11:11 PM
LS1TECH Sponsor
foff667's Avatar
I already posted in your thread on hptuners' forum, but do you care posting your file, maybe we can give you some pointers in the meantime before you get that wideband
Old 12-03-2006, 11:28 PM
Thanks Foff667, i uploaded them on HPTunners forum.. but ill upload them here too for folks to see.. the one that says 25 november is whati tunned FROM, the one that says 3 Dec.. is the changes i made to get it to idle.
thanks,
chris
File Type: hpt
File Type: hpt
Old 12-03-2006, 11:45 PM
do i need the Basic or the RPM LC1 wideband to work with the HPT EIO?
Old 12-04-2006, 06:39 AM
LS1TECH Sponsor
foff667's Avatar
basic.
Old 12-05-2006, 04:15 AM
Ttt...
