Big problems, 2 dead LS2 PCM's. Hptuners
Old 01-01-2007, 01:25 PM
Alvin's Avatar
Default Big problems, 2 dead LS2 PCM's. Hptuners
I was trying to build a backup PCM for a GTO I have so I got two LS2 GTO junkyard PCM's and tried to do a full re-write.
It did the re-write just fine, and validated the PCM OK but now I have no service engine soon light, no communications with PCM, etc.
Please tell me these PCM's are not toast now.
Old 01-01-2007, 03:16 PM
ringram's Avatar
I take it you have pulled power for a while and tried again?
Otherwise sounds like a job for HPT HQ Support!
Old 01-01-2007, 07:35 PM
GOaT Cheese's Avatar
Your problem is with the PIM. HP tuners can do a full re-write on the PCM, but it cannot burn the PIM (powertrain interface module) that needs to be done by the dealer with a satelite uplink and a CANdI module. Your PCM's are probably okay, they just need to be programmed to the vehicles PIM.
Old 01-01-2007, 08:12 PM
Alvin's Avatar
These are being done on a bench and I have literally done a crapload like this using EFIlive's V2. I've even re-written E40's that where out of completely different vehicles with efilive. Only reason why I used Hptuners is because I had the stock file left over when i started tuning it before EFIlive was out.
I'm thinking theres a problem with Hptuners full re-write..
Old 01-01-2007, 09:27 PM
LS1TECH Sponsor
Magnus's Avatar
http://www.hptuners.com/forum/showthread.php?t=9610
