EFILive Data logging not recording RPM
Old 01-05-2007, 01:21 PM
blackbird345's Avatar
Default EFILive Data logging not recording RPM
RPM is selected but when I log it it stays around 200 RPMs the whole time even when I do WOT runs. What am I doing wrong? It used to work...
Old 01-05-2007, 01:42 PM
ringram's Avatar
Check the PIDs are validated. Does everything else work ok?
Any codes?
Old 01-05-2007, 01:55 PM
TAQuickness's Avatar
Assuming from you title you have a firebird, are you sure you have sae.rpm selected and not gm.rpm24x?
Old 01-05-2007, 02:27 PM
joecar's Avatar
If you're BB logging, make sure the scan tool is displaying the correct VIN/OS numbers (at bottom of window) before programming the BB and before retrieving the log from the BB.
Old 01-05-2007, 06:43 PM
Fratsit's Avatar
Look here:
http://forum.efilive.com/showthread.php?t=3846
Look at post number 3. I had the same problem. Are you logging at least 13 channels?
R/
Frat
Old 01-06-2007, 03:44 AM
ringram's Avatar
Yeah good point, logging too many pids can cause it.
