Got hptuners:) confused:(
1 Post
I just got hptuners. I have cammed 02 w/ full boltons.
I have an lc-1 wideband installed and running through the egr.
I don't understand how to get my car to idle. Ive done quite a bit of reading but i am still confused. I can't find iac counts to log it and i cant figure out what the best method to get it to idle.
I took care of ses lights, and some basic options, I set up the scanner to log wideband through the egr. It logs the egr voltage/a/f ratio great ( ), however, A/F ratio error % doesnt work. This is the function I have: 100*((([PID.2811]/.625)+10) -[SENS.121])/[SENS.121].
I have my egr voltage, wideband a/f ratio, and a/f error % added to my table. Any idea why the Error % doesnt work?
I made some histogrtams such as stft+ltft, a/f to rpm, and a/f % to rpm. I did some logging earlier under the charts but all of my histograms are blank, do i have to log with the histograms open?
What do i do next? I am having a hard time finding options like Open loop f/a vs ect vs map. I really would like to get it to idle and not have to worrya bout it stalling everytime i let off the gas (sometimes it will hold idle for some reason).
is 13.0 a good a/f ratio to start with or should i try something else?
You should be aiming at 14.7:1 up to around 80kpa where you richen up for WOT
Otherwise you are needlessly burning fuel for no reason.
If you want more power, you put your foot down.
LS1TECH Sponsor
http://www.hptuners.com/help/demos/CustomHisto.swf
