Permanently Installing LM-1
Old 03-11-2007, 03:59 PM
BlkHwk's Avatar
Default Permanently Installing LM-1
I have an LM-1 I want to use for logging and also to run a AFR gauge in the A pillar. Who has their LM-1 permanently installed. Never have seen it but I have heard of people disassembling their LM-1 and finding a way to install it that way. I did a search and found that someone had asked the same question and there was only one suggestion about putting it under the seat.
Any Thoughts?
Old 03-11-2007, 04:36 PM
PurplePiss's Avatar
I made a clip out of a coat hanger and have it hanging from the mirror. I also taped the power wire to the case so it won't fall out. Wasted 2 WBO2 sensors because the power cord fell out.
Old 03-11-2007, 06:07 PM
BlkHwk's Avatar
Yea. I know they sell a windsheild attachment to hold the LM-1. I took the LM-1 appart and there really isn't much there. The screen and the board and a wire ribbon attaching the two. The screen could probably go where the TCS switch is. Only prob. would be where to put the board where you could still access the buttons for record and calibrate. Maybe easier to get an LC-1 cable for the gauge in the pillar.
