p0608
p0758
anyone ever have this code b4 just got done with the m6 to a4 swap, entire harness and pcm too, i have no speedometer reading and my tranny is not shifting right pcm was already programmed on the other car and worked fine, could it be the speed sensor?
i changed out the speed sensor now the speedometer works i get good 1-2 shift but i have no third during accel till i come to a stop then it says on the scanner that it is on third. and now i get code p0758 for the 2-3 solenoid. you guys think it might be stuck or should i just get a new 1. i read up on a diffrent post saying to turn off code p0751 i checked the tune and it is still on could that cause it? the stall is a vig 3200
