i wanna try a sd tune
i have no clue how to do it yet. i was hoping someone that has a sd tune can pm the file to me so i could look it over and get some ideas of what adjustments to make. i have a wb hooked up and have the time to do it right. i have hp tuners.
LS1TECH Sponsor
to enter speed density mode on your 02 SS just unplug the maf...its that simple to enter it.
Then its just a matter of tuning your volumetric efficiency table so that your commanded afr & actual afr match basically.
Theres a pretty good how to right in our help file which can be found here www.hptuners.com/help or by opening your editor or scanner & hitting F1 which basically runs you through the steps.
