Baseline Tune for F14 ?
Old 04-02-2007, 11:25 PM
LS1IMPULSE's Avatar
Default Baseline Tune for F14 ?
Im will be trying my hand at tuning my TA in the next few weeks after I finish up a few new installs and get a Wideband. Basically I am trying to find some baseline numbers to try to start tunning with. Any other advice/tips/tricks would also be greatly apreciated. Just for reference my performance mods are:
Engine:
-FMS F14 (232/234 .598/.598 112LSA +4)
-243 Casting LS6 heads with sodium filled valves (clean up milled .002)
-Patriot Gold dual spring kit
-Thunder Racing heat treated 7.400 chromemoly pushrods
-Roll master heat treated adjustable double roller timing set
-MTI Clear Induction lid w/ WIX paper filter
-Thunder Racing billet MAF ends, black
-Jantzer ported and black powder coated throttle body
-FAST LSX 78MM Intake
-March under drive pulley
-ARP Pro Series rod bolts
-Ported LS6 oil pump
-Prothane poly motor mounts
-Black Corvette FRC’s
Exhaust:
-Edelbrock Victor Series drag headers: 1 3/4" to 1 7/8" stepped long tubes with merge collectors and off-road y-pipe
-Hooker cat-back
Rearend:
-Driveline Solutions Built Ford 9" - 4.56 Geared Detroit TrueTrac, 31 spline axles, Strange SS case, Daytona pinion support, 1350 yoke, solid pinion spacer. 1/2" x 3" screw-in wheels studs
-Denny's Nitrous driveshaft (good to 2000 HP)
Free Mods:
-!CAGS
-!EGR
-!A.I.R.
-! A/C Delete
-Throttle body coolant bypass
-NGK Iridium plugs
Old 04-03-2007, 09:36 PM
LS1IMPULSE's Avatar
Old 04-04-2007, 01:14 PM
LS1IMPULSE's Avatar
Nobody with an F14 has a .bin file?
Old 04-27-2008, 07:04 PM
sixpack_2_go's Avatar
t t t
