HPTuners EIO output as TPS, window switch for Nitrous
Old 04-10-2007, 01:06 AM
jeff2380's Avatar
Default HPTuners EIO output as TPS, window switch for Nitrous
I'm just brainstorming, since I'll have HPTuners MVPI hooked up to the car to log anyway I was thinking of using an analog output to control the nitrous solnoids.
Could a custom PID be made that only outputs a signal to a relay?
Options could include:
1. over 85% throttle
2. over 3000 rpm
3. fuel pressure from sender (EIO Input) above a safe psi (is 50 too high?)
4. safe A/F ratio, (under 13:1?)
Has anyone done this before?
Old 04-10-2007, 01:35 AM
jeff2380's Avatar
Would this work? Testing with TPS and RPM
Enable trigger
[SENS.90] > 90 AND [SENS.70] > 3000
Disable trigger
[SENS.90] < 90 OR [SENS.70] < 3000
Is that the right syntax, I haven't done this before!
Old 04-10-2007, 03:12 PM
jeff2380's Avatar
no one?
Quick Reply: HPTuners EIO output as TPS, window switch for Nitrous
