MTI Stealth II Cam, .020 Cut Heads = Detonation??
OK, before I start, I know I need to get the car tuned. That being said, does it make sense that I will have low RPM/High load detonation? For example, starting off from a dead stop and part-throttle, quick clutch release? The temperature was in the 80's this weekend and the car just sounded terrible. I have MTI's Stealth II cam, LS6 heads that have been decked .020.
Is detonation what I'm hearing? Will the tune correct this? Will I lose power in the lower rpm ranges?
Thanks!
Brian
Thanks!
Brian
