Wideband and NO2..Please help
I have Dynotuned my car for NA and the A/F was good.
I have added a 150 wet shot and my A/F is lean. (14.75) What I need to know is, can i use a lC1 wideband to monitor my NO2 shot so i can make the appropriate fuel jet increases???
I really do not want to spend another 300 bucks on a Dyno again.....
Do any of the widebands do a playback on the gauge or show peaks after the run??? I do not have any Tuner so???are or tuning items.
Please help.
Thanks
Please help.
Thanks
Please help.
Thanks
Please help.
Thanks
Use your Wideband and jet accordingly, if the AFR does not get any better you may be out of Pump.
You can log with the LC1 it has the soft ware to do it (must use a laptop), it does not record the RPM or anything just AFR plotted against time, but you should be able to figure out where you hit it and let off. Other Widebands Include logging soft ware as well.
