EFILive 2 Step...ok for FI? Anybody using?
Anybody using the EFILive 2-step function on their forced induction car? The method used to control rpm is fuel cut. I always thought cutting fuel in a forced induction car was a no-no. Any thoughts? Is it safe?
Originally Posted by wait4me
Depends on if you are making boost at that rpm cutoff point.
Yep, a fuel is cutoff it is not lean, it is a air pump. Also flame temperature starts falling off FAST after 14.7 so even if there is some fuel kicking around there is not much to go on and without a stratified charge knock is nearly impossible.
