Need help identifing a plug and a part
First the plug. '01 F-body it comes out of the harness that goes into both doors. More specifically it comes out on the driver side "into door" harness...it's a long wire too. The picture is of the connector...I just need to know what it goes to.
Now the part it's some sort of module mounted on the driver side frame rail below the abs block and kind of next to the air pump. It has a 10 pin conncetor. What is this module?
Thanks in advance.
Thanks in advance.
The problem is that the wiring diagrams are divided up by area - doors, seats, etc., I can't find a refernece to the connector.
The module in the front may be the throttle control motor module.
What is that throttle control motor module? There is a throttle control module under the dash that I assume is for the traction control. But the non traction control cars have that module on the frame rail also.
Thanks though.
