Megasquirt and tuning in the UK
has anyone made any further advances for decoding the timing of the LSx trigger wheel in regards to megaquirt?
also does anyone know of anybody in the UK who can tune ECUs? i don't really fancy spedning $600 on HP tuner or similar!
the issue i have is that i am likely to need to go through a number of ECUs in my life (they will get drowned in a big puddle)- i don't really want to pay out all those $$ just to put a replacement ECU in.
They are waterproof almost. If you remove the cover silicone them and also silicone around the connectors seals and the wiring harness plug ins that should make it 100% water tight.
You can download EFI Live's software, and a tune relevent to your ECU/Engine year and have a play with it to see if you like it (efilive.com). Richard Ingram is the UK stockist and all round good egg.
One alternative would be to look at the OMEX set up, I know GD use this on their LS setups, but I've no idea on what the cost is.
Rgds
Jim
Rgds
Jim
