manually resetting PCM
Old 07-12-2007, 04:53 PM
Bryan @ Speed Inc.'s Avatar
Default manually resetting PCM
the search is taking forever - i need to manually reset my pcm. i have a bad o2 sensor. i'm going to replace it with a new one, what do i need to do to reset it to "clear" the codes.
Old 07-12-2007, 05:05 PM
2001NBMZ28's Avatar
Here's one way:
Turn key on, don't start car
Pull PCM BATT and PCM IGN fuses in engine compartment
Wait 5-10 min
Turn ignition off
Replace fuses
Idle will be grumpy until it relearns and resets the emissions readiness tests.
Old 07-12-2007, 10:42 PM
LS1Tech Sponsor
06MonteSS's Avatar
or, just remove your negative battery cable for about 15-20 minutes...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 07-13-2007, 10:20 AM
thanks guys... i was trying to remember which fuses to pull! PCM batt and IGN. that's what i was lookin' for!
